Author Topic: Chosster's Last Stand  (Read 8567 times)
« on: November 16, 2014, 04:26:51 PM »
Here's a couple of shots from yesterday - clink and I did Northern Lights 5.6R.
Wish I had a shot of my jump from the Geronimo Ledge.
I tried the climb part of the "climb or jump down" option described in the guidebook but everything I touched disintegrated. There was a big knob that I thought would be the key to getting down. I reverse mantled off a gravel-covered ledge and as my toe barely touched the large knob - it fell off and tumbled down the chasm below. Kat and clink heard it and thought the next thing they would see was me taking a monstrous swing out of the chasm.Only two options left at that point - reverse the route and bail or jump...Scary! Reversing the route was out of the question so I decided to jump. with my hands and butt on the ledge and my feet against the wall I pulled plenty of slack into the rope and psyched myself up. I pushed off with every ounce of strength I had and stuck the landing. When I caught my breath I yelled - "I jumped!...I'm Okay!" After I built a questionable gear belay and called off belay - I yelled - "KAT! DON'T FOLLOW THIS ROUTE!!!"
Working toward the bolt with a couple big cams in
Moving past the bolt on some seriously crunchy rock
clink follows - terror awaits the follower after unclipping the bolt - if you fall you are either going to the hospital or the morgue.
Grateful to be on top, alive and have a partner like clink
Thanks to Kat too for the support :)
Re: Chosster's Last Stand
« Reply #1 on: November 16, 2014, 04:53:25 PM »
The crack is longer than I remember.
« Reply #2 on: November 16, 2014, 05:09:52 PM »
The ground was closer than I remember.
Any Munchkins crawling around?
« Reply #3 on: November 16, 2014, 05:18:06 PM »
the jump was fun.
« Reply #4 on: November 16, 2014, 05:32:58 PM »
rapid deceleration syndrome
« Reply #5 on: November 16, 2014, 05:34:05 PM »
Yeah, I agree.
« Reply #6 on: November 16, 2014, 06:39:27 PM »
Does the route need more soft brushing?
« Reply #7 on: November 16, 2014, 07:36:24 PM »
go for it
« Reply #8 on: November 17, 2014, 08:05:28 AM »
What's the typical ape index on a Munchkin clink?
Puny Legs could also increase the difficulty factor :)
« Reply #9 on: November 17, 2014, 01:29:14 PM »
Male or female?
« Reply #10 on: November 17, 2014, 05:43:36 PM »
Cooks got in touch with their inner boulderer. JC even went back for seconds.
« Reply #11 on: November 17, 2014, 07:42:30 PM »
That's record three posts in a row that I:
1. Could read and understand; but
2. Had no idea what the hell they were talking about.
« Reply #12 on: November 17, 2014, 09:07:29 PM »
I will second the last post.
« Reply #13 on: November 17, 2014, 09:13:33 PM »
Yep it was pretty cool us each getting the coveted second ascent of each other's routes - esp mine of the Route Formerly Known as M.E. :)
« Reply #14 on: November 18, 2014, 06:05:01 AM »
Munchkin 5.9 is a new "sombrero" type route, at 24' high it required no bolts (true Munge fashion) so may not actually exist. Cool holds to Pinns rap.
This was a follow up on a follow up trying to repeat a boltless Mungeventure, and led to more >:D This above sentence is for Brad and Mud.
I am determined to see JC lead a 5.10 this season at Pinns. After Munchkin I am convinced he will. What about that route on the Sisters you have been eyeballing JC?
Aaron, let me know if an attempt on Godzilla's testicle bypass is a possibility.
« Reply #15 on: November 18, 2014, 01:49:05 PM »
somehow this seems like a good route name
« Reply #16 on: November 18, 2014, 02:14:34 PM »
« Reply #17 on: November 18, 2014, 05:12:25 PM »
well I have no desire to be a SNAG ( Sensitive New Age Geezer ) so I am going with my original post that it is a good route name.  Plus Clint seems to insinuate that crass is good so it absolutely has to be good.
« Reply #18 on: November 19, 2014, 06:47:35 AM »
Yes, but other parts of Godzilla's anatomy might become fair name game.
